This is bonding, not grounding questions.
I have read thru;
ARRL General Class License Manual Chapter 5.5
ARRL Handbook Volume 5 Chapter 22.1.8
publications on RF bonding and I have a few questions on what should be bonded and what doesn't have to be.
Do these have to be bonded?;
1. Electrical electronic equipment in non-metallic (plastic) enclosures,
2. PC related, monitors, printers, copiers, Laptops (other than Towers in a metal enclosure),
3. Network equipment; Routers, VOIP adapters, Switches etc,
4. Equipment in metal enclosures that are DC powered thru a DC wall adapter, CCTV DVR,
5. Scanner receivers connected to a grounded roof antenna,
6. Test equipment in plastic enclosures with earth ground; Spectrum Analyzers, Scopes, etc,
7. Metal file cabinets or desks (non metal top, metal drawers),
8. Telephones, lamps with metal bases, metal enclosed Bench Power Supplies,
9. Lastly a Dual band 50w (almost always set for 5w out) mobile and/or a metal case PS.
All of this is in a 2nd floor room in a 'double' home with a #6 gauge ground wire tied to the electrical ground via two 8' ground rods. The AC outlet is grounded where everything gets run to thru power strips.
I have read thru;
