Is it interference coming from something nearby?Any suggestions?
What radio, and how is power supplied? I have an FTM-400XDR powered (for now) via the 12V socket in the center console of my 2011 F250 diesel, and I have not noticed any such issues.The vehicle in question is a 2015 F250 with the Diesel engine.
OK, Diesel, so not ignition.
Yeah, computer noise, fuel pump, etc.
Probably the easiest thing to do is take a hand held VHF radio with the antenna removed and start sniffing around and see if you can track it down.
I've got a 2018 with a Diesel and a VHF radio, no issues, but I'm sure there is some differences between those model years.
thank you for the suggestion. I just tried it with and without the antenna and couldn’t find anything. Tried it on the same frequency that the mobile unit is showing the noise on. Swept under the hood and under the truck.
I have this same problem with a two meter rig in the car. The car is a Honda. They use a 3.58mhz clocking crystal in the ecu. Turns out that the
41st harmonic of 3.58 is 146.78. You may have a different brand of car but they all seem to use the came clocking in the ecu. It only bothers me
when trying to scan on the Icom rig. It causes problems with the local repeater on 146.76.
I will try clip on chokes on the input and out put of the ecu if I can get them to fit the various cables in question.
OK, lets start looking at the installation.
Is this a new install? Or and existing install that just started doing it recently?
How is the radio chassis grounded? Try running a short ground strap from the radio chassis to the vehicle body.
no the problem has been there since it was first installed, I’m just recently paying attention to it. The reason why is because I got a reply over the radio that said I was fading out. I don’t make a lot of contacts because of where I live.
the radio is grounded to a bolt on the cab and the cab is ground-strapped to the frame. The antenna connector is also supplying ground for the radio that keeps it powered when the ground wire is not connected to anything.
I’ll run a wire from the body to the cab/chassis and see what it does.
WAG. On the location where the NMO is sited, did you sandpaper or otherwise clean/clear the underside of the metal roof/fender/??? so the mount bites into metal and not paint or rustproofing or ?
I assume you have used an ohmmeter to ensure (1) continuity on both the center and the shield of the coax and (2) there is no short between the center and the shield.
Your dealer should have access to a supplemental service manual(s) that address electrical noise.
HTH a bit.
You might want to check on your coax and power wiring, make sure it's not running up tight agains other vehicle wiring.
I did not sand the underside but assume it’s properly grounded as it’s providing a sufficient ground to power the radio.
The antenna mount is providing the ground to power the radio?
