77monarch77
I hate to start WWIII here as there are probably many different ways of answering this question. Let's say that there is X amount of feet of lead-in coax. Between where it enters a building and where it connects to a receiver is, let's say, 10 feet. Let's also say, for the sake of argument, that everything about the antenna install is absolutely perfect (yeah, right). The situation is that there is 10 to 20 feet or so of additional coax that's just sitting there. Provided that you don't want to cut this extra, for whatever reason, what do you do with it? Do you coil the additional? Would you figure-8 it? Does it matter?
I used to install cellular phones in vehicles. The rule-of-thumb, at least what I was TOLD to do, was to figure-8 the additional. The reason was due to MRI induced into the reception signal, if the coax was coiled, radiating from various electrical and/or electronic devices and/or systems already in the vehicle. The amount of MRI was supposed to be amplified (although I don't know to what degree) if the coax was coiled versus if it was not.
Does similar logic apply in the above instance?
