RFSS/Site issues
Skyhawk9
Medina, Oh
Hoping someone can help me figure this out.. I have the Unification G5 (using it as a scanner) and it has been working great for the most part (listening to P25 ohio MARCS in the cleveland area), but recently I've been having some RFSS/Site problems. I live in Medina County Ohio and normally the RFSS/Site has been 2/1.. With this I was able to capture pretty much all my frequencies with an all scan option I have set up in my zone 1 channel 1 position. NOW for some reason the RFSS/Site is 2/2..and I only get half the traffic I used to. Does anyone know how to fix this issue? thank you all in advance. Im still a bit new to the G5 so sorry if this post maybe a bit confusing.
N6ML
Sounds like you have multiple sites programmed for the system. You may want to create separate systems, each including a single site (the one(s) that carry your talkgroups of interest). Looks like site 2/54 (decimal) is the one for Medina Co?
Skyhawk9
Medina, Oh
Sounds good I will try this..yes Medina Co is 2/54. Thank you N6ML. I do move around a bit between counties here but my home county is Medina. I bounce between Cuyahoga/Medina/Geauga counties. So setup for each of these correct? Thanks again
N6ML
Yeah, if you want to be in full control, program each in a separate system, and then you'll need a separate set of knob positions using each.
LEH
Yorktown, Virginia
This is one of the benefits and problems with the Unication receivers. They are almost too good.
Multi-site systems like MARC can be a nightmare if the pager locks onto an unwanted tower. I live about 30 minutes from North Carolina and their VIPER system presents similar challenges when I go through.
The suggestion to set up a knob position for each site would work, but then you would need to know when and where you need to change to a different site. Having all nearby sites in one knob position simplifies the monitoring, but with the Unication staying locked onto a signal even if there is a stronger one, can be (as we see here) a problem.
As N6ML pointed out, your best site would be the Medina County (2/54) site, but depending on where you are (if you are in Medina County and where as well) other sites you could also pick up might be 2/27 (Lorain), 2/61 or 2/55 (Wayne), or 2.2 (Summit but only east side of Medina). That is just from looking at rough coverage maps on RR.
If I still lived in Ohio, my Unication would be dedicated to as local the systems as I could get even it meant merging the two or three closest tower control channels. Any travel I would turn to my 436 and hope for the best.
You have a tough decision to make on how to program.
Skyhawk9
Medina, Oh
All great information..I really appreciate the feed-back. I will have to do some re programming..A definite trial and error. A great little pager/scanner. Wish there was an the option to lock in and stay on a single tower in an all scan function. Thanks again guys
