It has already been settled that you're looking at the wrong cable for that long a run so why are you not looking for lower loss cable? Of course you won't overload the R20 with a big attenuator between it and a less than unity gain antenna... sheesh! One thing that hasn't been mentioned but should be, a hand held antenna sucks raw eggs to begin with, it is only used for portable because of its small size. Aside from low loss cable you need an antenna right for the job unless you want to end up with less than you started with.
