I want to be able to connect the power leads from the 15X and the RH-96 to a single switch that will turn both units on and off. On my test bench, when I have the two units connected independently, I turn off the RH-96 first and it displays the message: not to turn off the scanner until the RH-96 is off (or something very close to that). Will I damage either unit by having them connected to a single power switch?
Thank you.
Thank you.
