RIB to PC cable
intuity
Dallas, TX
I recently scored a real RLN4008D RIB and upon unboxing, I see it has a 15 pin D-sub connector on the PC side - I might regret asking this, but does anyone know how those pins map back to a 25-pin or 9-pin layout, or know where to find the OEM cable? eBay is striking out, all I find are cables for the Spectra 15-pin connector, and I already have one of those.
Maybe a M part number? I wasn’t able to find any pinout listings on any of the other boards or even anything here, so any advice would be helpful!
merlin
DN32su
Get a DSM for the rib, It will have the P/N for the cable and evenpinouts to build yourself one.
Let me see if I can post it here.
  • motorola_rln-4008d.pdf
buddrousa
Yes but like I posted depends on the Radios. The old Radio Shop I worked at still has a SX-386 PC running less that 20Meg CPU for older Motorolas. My boss learned the hard way Bricked a new out of the box Visar 800.
KJ4DHF
Order you a 15 pin M to 15 pin female shielded serial cable. Chop off end you do not need. Order a good DB9 female for pc end and make the connections. A good DB 9 F cost you more than the serial cable. My brother made mine using TE Connectivity 9 pin and 15 pin crimp pin connectors.He had the correct crimp tool so that was no cost.
intuity
Dallas, TX
Wow, l don’t know how I missed the info on batlabs - I have gone in search of pinouts for a few different radio RIB cables there and I guess I completely skipped over the link to the RIB to PC cable link..
I have used a Ganz-style RIB clone for about 14 years with several different 286 and 386 machines, for successful programming of many of the HT’s and mobiles I have owned and used.. Spectras, MaxTracs, my venerable workhorse Maratracs, and it worked every time, so long as the cables I made were good and the radio got power ;)
I found the RIB on ebay as a BIN for $20.00, NIB, free shipping - by chance it was posted barely an hour before I ran across it - and not much later it was sold - so I can’t wait to try it out.
Thanks,
JB
