Rich/Henrico/Chesterfield System
WesFFXFire
Fairfax County Virginia
Can someone help. I have a Bearcat 296 and have Richmond/Chesterfield/Henrico all programmed in the same bank. But I've been down to Richmond twice in the last week and can't seem to hear anything. Since it's all one system I can program all of them in one bank right ????? Or is there some special order to program the Control channels ????? Thanks for any help.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Any order is ok, but do you hear a CC?
I think all you need is the duty CC for Richmond, which is one of these.
Also you need to set the CC only plan. These freqs are plan 2.
868.5125
868.7000
868.8250
868.9500
WesFFXFire
Ok, I hear the control channels. I think I have it set to plan 1.....I'll change it and try tomorrow night when I'm down for the races.........Thank for the help !!!
fmon
Eclipse, Virginia
WesFFXFire said:
One more question, how do I tell what plan a system is on ???
Your owner’s manual should define the four plans in the Control Channel Only Mode near the end of the Motorola Tracking section. I listed the Richmond plan in my previous, however if you have all available freqs programmed, then you can disregard CC Only Mode.
WesFFXFire
Thanks, but I do only have the CC'c programmed in.....Tks (When I got the scanner I cheated and had someone else program everything for me.....so I'm learning as I go along)
fmon
Eclipse, Virginia
Software is the best method for programming, but wearing out you fingers using the menu system and of course, reading the manual will help understand the scanner better. Sounds like you are doing well, keep it up.
eweiner
Wes,
You'll notice down here that you'll hear TG's for Henrico on the City banks and/or the Chesterfield banks--and in all combinations of the above scenario. The system is coordinated so that if a unit from a jursidiction is closer to a tower of another jurisdiction, the TG's will come across the closest tower. All of the units for all three jurisdictions have ACCESS to the TG's for the others for situations like M/A, etc.
E:
n4jri
Richmond, VA
I'm not familiar with the operation of the BC296, but on the RS PRO96 you can program CC's for all three systems into the same bank--just like it comes from Radio Shack.
It seems to me that any radio scanning control channels should operate on whatever CC it lands on. Richmond, Henrico and Chesterfield have their TG numbers coordinated so that there is no duplication, and so that units can roam from locality to locality.
I can generally hear police and fire dispatch TG's from at least two different localities on any control channel I land on. So it's no sweat if I'm listening to a Chesterfield CC but want also to hear activity in Richmond & Henrico.
Other TGs, however, may be more restricted. I rarely hear a public works unit from one locality on another's CC, and that's also true of police and fire TGs dedicated to administration, surveillance, etc. Not sure about Fire TACs for that matter.
If you use separate banks, I would keep a couple of sub-banks open in each bank for police and fire dispatch TGs from other localities. That way, they'll be identified on your display if you hear them in a different bank than the one assigned to their locality.
73/Allen (N4JRI)
n4jri
Richmond, VA
None other! Did we run into each other over by Cabo's in the last month or so?
n4jri
Richmond, VA
Sounds good, Joe. BTW, one thing that I would like to mention on this thread is that Central Virginia Radio Enthusiasts will probably be meeting in Richmond sometime in October or November. I don't have solid data, but googling the group's name should produce some.
73/Allen (N4JRI)
N4RVR
Chester, VA, USA
Next CVRE Meeting
73/Allen (N4JRI)
The next CVRE meeting is October 9th at 1 P.M. at the Meadowdale Library in Chesterfield County.
http://mywebpages.comcast.net/trunkscan/cvre.html
N4RVR
