Richardson Fire Department (Texas)
KB5RKM
Richardson Texas
It appears that all transmissions have ceased within the last couple of days for the Richardson Fire Department… I”ve been listening using a Uniden SDS-100 and the broadcastify feed and both are now silent. I assume this means that everything in this city is now locked down and encrypted?
Have you been watching the SDS display screen for the ENC icon?
KB5RKM
Richardson Texas
No I have not as transmissions are fairly infrequent. I think I have a broken scanner as there is an error code C71h flashing. I reset scanner and now all I have is static. So the famous “cold-solder joint” problem? Still does not explain the broadcasting feed being silent yet “online” as well.
KB5RKM
Richardson Texas
I reset my radio and then reprogrammed and the error code is gone so who know what malfunction that was. I am now receiving again.
I really appreciate the help with confirming that the transmissions were being received by others and that it was my radio all along.
ChrisP
Portland, OR
I don't think the flashing "C17h" is an error code, but the P-25 network access code (NAC) of the transmission you were listening to.
- Chris
KB5RKM
Richardson Texas
- Chris
Sounds plausible, it has happened intermittently and each time it does the radio goes silent until I reboot the radio. This might be what has knocked the broadcastify feed off as well.
