Richardson Texas
wendallb
Blue Ridge, Tx
I programmed my Pro-97 with Win-97 and all works well except I have not heard anything at all on the Richardson Freq's???
I wonder if the freqs are correct in the data base.
KE5BCP
Analog Man
Lewisville, Texas
They seem to be working fine.
Make sure you have both the bank as well as each channel set to EDACS.
Also make sure you have the channels in LCN order, and NOT beginning in channel "0".
wendallb
Blue Ridge, Tx
Not
Well I checked the channels and I had one wrong. The bank is marked edacs and each channel is listed in order and marked edacs but still nothing. I have one primary channel and 6 other channels programmed. First channel is on channel 2.
rpowley
Rowlett, Texas
The 1/st entry should be on (01) of whatever bank you are using - If you are using Bank 1, skip 100 and put your 1/st frequency in 101.
101) 867.20000* 102) 867.25000 103) 867.27500 104) 867.30000 105) 867.32500
106) 867.35000 107) 867.37500
