Richland county using palmetto 800
lugoffman
Spring Hill, Florida
Richland Co. SD operates entirely on the Palmetto 800 does any one have these frequencys i see were the old ones are in the rr data base but do they still use them also the richland county city police are using digatal talk groups does any one have anything about that as well
brian
DB Administrator
South Carolina
You would program 860.3375 as the control channel frequency for cell 30, the Richland Co. simulcast. That's listed in that big list of frequencies on the Palmetto 800 database page.
But if you're not in range to receive that control channel, you're not going to hear it. Program that frequency into the scanner and listen for the idling diesel engine noise. If you don't hear it, you'll need a better antenna, or you'll need to move closer to the transmitter. Being in Lugoff you're probably close to being in range, but likely on the fringe.
2J144
Ok first off for a Pro-97 you wont be able to get the City of columbia it wont do digital. Ok, that out of the way, you will be able to get Richland SO, Richland County Fire & EMS.
All you have to do is program in these tower comtrol channels, and the following Talk Group ID's
860.48750 - HARBISON TOWER
868.03750 - RICHLAND TOWER 3
860.33750 - RICHLAND TOWER 1
868.53750 - RICHLAND TOWER 2
867.53750 - RICHLAND TOWER 4
16016 - Richland Co. SD S.R.T*
16528 - Richland Co. SD TAC 01 Region 1 Dispatch*
16432 - Richland Co. SD TAC 02 Region 2 Dispatch*
15952 - Richland Co. SD TAC 03 Region 3 and 6 Dispatch*
16176 - Richland Co. SD TAC 04 Region 4 Dispatch*
16496 - Richland Co. SD TAC 05 Statewide Roam*
16208 - Richland Co. SD TAC 06 Region 2,3,6 Talk-around*
16368 - Richland Co. SD TAC 07 Region 1,4 Talk-around*
16400 - Richland Co. SD TAC 08 Community Action Team (CAT)*
15984 - Richland Co. SD TAC 09 Investigations*
16464 - Richland Co. SD TAC 10 Records*
11152 - Richland Co. SD TAC 12 Special Ops*
15856 - Richland Co. SD TAC 13 Courthouse 1*
15888 - Richland Co. SD TAC 14 Courthouse 2*
15920 - Richland Co. SD TAC 15 County Admin Building Security
42864 - CFD ADMIN1 - Columbia FD Admin 1*
42896 - CFD ADMIN2 - Columbia FD Admin 2*
42928 - CFD ADMIN3 - Columbia FD Admin 3*
16128 - COLUMBIA FD CH 01 DOWNTOWN OPS/BAT 1 (Old)*
16560 - COLUMBIA FD CH 02 NE OPS DISPATCH/BAT 3 (Old)*
16592 - COLUMBIA FD CH 03 NW OPS DISPATCH/BAT 2 (Old)*
16624 - COLUMBIA FD CH 04 SE OPS DISPATCH/BAT 4 (Old)*
16656 - COLUMBIA FD CH 05 BLYTHEWOOD OPS DISPATCH/BAT 3 (Old)*
42640 - CFD CMD 1 - Columbia FD Command 1*
42704 - CFD CMD 2 - Columbia FD Command 2*
42576 - CFD DISP - Columbia FD Dispatch Channel*
42608 - CFD OPS 1 - Columbia FD Ops 1*
42672 - CFD OPS 2 - Columbia FD Ops 2*
42736 - CFD TAC 1 - Columbia FD Tac 1*
42768 - CFD TAC 2 - Columbia FD Tac 2*
42800 - CFD TAC 3 - Columbia FD Tac 3*
42832 - CFD TAC 4 - Columbia FD Tac 4*
3920 - HELICOPTER* CAREFORCE
3888 - HELICOPTER* LIFE-REACH
6672 - HOSPITAL Palmetto Baptist Medical Center*
3952 - HOSPITAL PALMETTO RICHLAND MEMORIAL HOSP. NICU
60608 - Richland Co. Emergency Services*
16032 - Richland Co. EMS CH 01*
16096 - Richland Co. EMS CH 02 To Hospital*
16256 - Richland Co. EMS CH 03*
16272 - Richland Co. EMS CH 04 Supervisors*
16080 - Richland Co. EMS Ch 06*/ Public Safety
16048 - Richland Co. EMS Ch 07 Special Events*
16288 - Richland Co. EMS Media*
brian
DB Administrator
South Carolina
In fact, you need only program the control channel, 860.4875. The PRO-97 ignores all channels programmed in the MOT mode that aren't control channels, and this one rarely if ever changes.
And why not also program the control channel for site 30, Richland simulcast, 860.3375, which covers a much larger portion of Richland County than site 44?
lugoffman
do i program these under mot or ct cause i just bought me a larsen nmo 150/450/800mhz antenna and im picking up a lot more stuff
Caesar
Cayce, SC
lugoffman said:
i went to richland county today and i heard alot of ems and some police but alot of the frequencys poped up with the diesal noise
some of those might have been digital or encrypted transmissions if you had it in search mode...
rbellows
Midlands, SC
If they are digital, you will need a PRO-96 or similarly digital capable scanner. (Break out the Platinum Card) ; if they are encrypted, forget about them.
brian
DB Administrator
South Carolina
Well, in the sense that a PRO-96 can decode digital voice on talkgroups used by, for instance, Columbia PD, then yes, it's a better scanner than the PRO-97. It's also more than twice the cost ($150 on sale for the 97 vs. $399 on sale for the PRO-96).
The PRO-97 has 100 channels per bank (vs. only 50 on the PRO-96) and has 16 characters available for alpha-tags (vs. only 12 on the PRO-96). So there are some ways that the PRO-97 is better.
The GRE PSR-500 is probably the best thing going these days, though. And it's around $500 anywhere you buy it, and it's not available at RadioShack.
lugoffman
hey do they have layaway for the GRE PSR-500 HAHAHAHA LOL!!!!!!!!! IM GOING TO HAVE TO GET ME ONE BUT FIRST I GOT TO LEARN THE ONE I GOT BEFORE I STEP UP TO ANOTHER ONE WHAT IS THE BENNIFIT THOUGH FOR THIS SCANNER THE GRE PSR -500 ??
