I found these risers recently and they are very nice quality, inexpensive, sturdy, configurable and look great. I'll post some pictures in a few day on how I put them to use in my shack.
I made one a little taller than normal by borrowing a couple leg segments and added them to the other, than stacked them!
5Rcom Dual Computer Monitor Stand Riser, 2 Pack Height Adjustable Monitor Stand with Tempered Glass, Stackable Desktop Monitor Risers for 2 Monitors, PC, Under Monitor Desk Organizer, Black
About this item
About this item
- ☝Detachable Monitor Stand Legs - The heights of the computer monitor stand for desk can be adjusted to 0.6", 1.8", 3", 4.2" by adding or removing the leg blocks. With the legs being stackable, you will be able to make back legs shorter than the front. An effective way to accomplish the height you need to raise your screen to perfect eye level at work in home office, and help reduce neck and back strain for you being at the computer all day.
- ☝Extra Desk Space - 16.5"L * 9.4"W *4.4"H, this glass monitor stand is suitable for most electronic devices. The space between legs is 13.1"L * 6"W. The double computer riser stands clear up desk space and allow for more storage underneath platforms. You can store some peripherals underneath it, and hide the keyboard under it when not using or keep papers and office supplies neatly tucked out of the way.
- ☝Sturdy Black Monitor Stand - The desk monitor stand riser is made of black tempered glass platform and sturdy legs, it can easily hold up to 88 lbs laptop, monitor, printer, pc or all flat screen display. The inserts fit snugly with a very clean seam line where they go together. Appearance is sharp, with comfortably rounded edges.The design looks sleek and pretty nice with black desk.
- ☝Flexible Combination - You will love the flexibility these adjustable monitor risers provide. They can be used as monitor stands for 2 monitors. If you only want one stand, you can also use the extra legs from the other stand to make it higher and forms two tiers of storage space. With the non-slip feet, it also doesn't wobble or slide easily and can reduce scratches on wooden desk.
- ☝No Tool Assembly in 1 Minute - Super easy to put together these computer risers and pretty impressive quality once assembled. Just insert the number of leg segments that are required for the desired height and you are done. The computer lift for desk is super easy to put together. No tools, drilling, or worries about misaligned screws and split wood.
