uhf and 800mhz toned stuff i have for lauphlin and bullhead
Display Frequency L/O Tone Tone LO Att Pri Step Mod NAC AudioType Alt Tone Alt Level Alt Color Alt Pat Vol Adj Num Tag Rec Out Comment
451.1025MHz 451.10250 False 156.7Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
451.1750MHz 451.17500 False 151.4Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
451.2125MHz 451.21250 False 196.6Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
GNUG 451.76250 False DCS 413 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
HKEEP 451.80000 False 179.9Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
451.9500MHz 451.95000 False DCS 703 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
451.9500MHz 451.95000 False DCS 205 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
452.0250MHz 452.02500 False DCS 174 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
452.1125MHz 452.11250 False DCS 071 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
TROP 452.75000 False DCS 116 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
PNR 452.77500 False DCS 662 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
Desert Cab 452.87500 False DCS 205 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
PNR 452.97500 False DCS 754 False False False AUTO FM Analog Only 0 0 Off On 3 NONE False
453.8400MHz 453.84000 False 118.8Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
454.6000MHz 454.60000 False DCS 411 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
456.6125MHz 456.61250 False DCS 023 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
456.8000MHz 456.80000 False 179.9Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
456.8125MHz 456.81250 False DCS 025 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
457.5125MHz 457.51250 False 71.9Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
Business 457.53750 False DCS 023 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
Business 457.58750 False DCS 703 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
457.8750MHz 457.87500 False DCS 205 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
ARIZONASTATEOF 460.47500 False 100.0Hz False False True AUTO AUTO Analog Only 0 0 Off On 3 NONE False
RVRSD 461.01250 False DCS 032 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
AQRS 461.02500 False DCS 356 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
461.0400MHz 461.04000 False DCS 023 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
SLOT 461.04750 False DCS 023 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
RVRSD 461.05000 False DCS 023 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
461.0550MHz 461.05500 False DCS 023 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
AQRS 461.13750 False DCS 172 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
461.2250MHz 461.22500 False 146.2Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
461.3475MHz 461.34750 False 114.8Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
EDWTR 461.35000 False 114.8Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
TROP 461.37500 False 94.8Hz False False False AUTO AUTO Analog Only 0 0 Off On 0 NONE False
461.4500MHz 461.45000 False DCS 205 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
TROP 461.47500 False DCS 734 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
HRAH 461.52500 False DCS 114 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
GNUG 461.63750 False DCS 413 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
SEC 461.66870 False DCS 032 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
SEC 461.67000 False DCS 032 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
RVRSD 461.67500 False DCS 032 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
461.6775MHz 461.67750 False DCS 032 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
461.7125MHz 461.71250 False 196.6Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
GNUG 461.78750 False 118.8Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
CBLL 461.92500 False 162.2Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
Mojave Golf 461.95000 False DCS 455 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
461.9750MHz 461.97500 False DCS 072 False False False AUTO NFM Analog Only 0 0 Off On 2 NONE False
461.9775MHz 461.97750 False DCS 072 False False False AUTO NFM Analog Only 0 0 Off On 2 NONE False
462.0000MHz 462.00000 False DCS 703 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
TROP 462.02500 False 103.5Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
RVRSD 462.27500 False DCS 205 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
462.2775MHz 462.27750 False DCS 205 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
PNR 462.47500 False DCS 754 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
AMR LAUGHLN 462.97500 False DCS 271 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
462.9750MHz 462.97500 False 123.0Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
MED 463.07500 False 136.5Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
AQRS 463.30000 False DCS 364 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
HRAH 463.32500 False DCS 315 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
RPLM 463.35000 False DCS 654 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
463.3725MHz 463.37250 False DCS 413 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
GNUG 463.37500 False DCS 413 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
RVRSD 463.42500 False DCS 032 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
TROP 463.45000 False 103.5Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
EDWTR 463.52500 False 107.2Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
CBLL 463.60000 False 131.8Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
463.6687MHz 463.66870 False DCS 156 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
463.6725MHz 463.67250 False DCS 156 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
RVRSD 463.67500 False DCS 156 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
EDWTR 463.70000 False 100.0Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
RVRSD/AQRS 463.72500 False DCS 703 False False False AUTO AUTO Analog Only 0 0 Off On 0 NONE False
Casino Ops 463.72500 False DCS 032 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
CBLL 463.77500 False 100.0Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
PNR 463.80000 False 94.8Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
463.8225MHz 463.82250 False DCS 261 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
HRAH 463.82500 False DCS 261 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
RPLM 463.95000 False DCS 072 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
CBLL 464.32500 False 100.0Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
GNUG 464.37500 False DCS 413 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
EDWTR 464.42500 False 123.0Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
HRAH 464.47500 False 100.0Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
EDWTR 464.67500 False 82.5Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
HKEEP 464.71250 False 110.9Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
464.7500MHz 464.75000 False 233.6Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
RPLM 464.77500 False DCS 134 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
464.7900MHz 464.79000 False 82.5Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
464.7975MHz 464.79750 False 82.5Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
CBLL/EDWTR 464.80000 False 82.5Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
MED 464.83750 False DCS 243 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
AQRS 464.90000 False DCS 116 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
HRAH 464.92500 False DCS 162 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
466.0500MHz 466.05000 False DCS 023 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
466.3500MHz 466.35000 False 114.8Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
466.4500MHz 466.45000 False DCS 205 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
466.6750MHz 466.67500 False DCS 032 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
Mojave Golf 466.95000 False DCS 455 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
466.9750MHz 466.97500 False DCS 072 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
467.6125MHz 467.61250 False 82.5Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
467.8500MHz 467.85000 False DCS 306 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
467.8875MHz 467.88750 False 179.9Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
468.0250MHz 468.02500 False 192.8Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
468.0750MHz 468.07500 False 136.5Hz False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
468.3250MHz 468.32500 False DCS 315 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
468.3750MHz 468.37500 False DCS 413 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
468.4250MHz 468.42500 False DCS 032 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
468.6750MHz 468.67500 False DCS 156 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
468.7250MHz 468.72500 False DCS 032 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
468.7275MHz 468.72750 False DCS 032 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
469.8375MHz 469.83750 False DCS 243 False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
CBLL 855.06250 False DCS 134 False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
Casino Ops 855.26250 False DCS 071 False False False AUTO NFM Analog Only 0 0 Off On 3 NONE False
855.3125MHz 855.31250 False 241.8Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
855.5375MHz 855.53750 False 74.4Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
855.5625MHz 855.56250 False 123.0Hz False False False AUTO NFM Analog Only 0 0 Off On 0 NONE False
RVRSD 860.78750 False 136.5Hz False False False AUTO FM Analog Only 0 0 Off On 0 NONE False
