RLN4008 vs RLN4008B
MOCOMD1
It isnt software, they are, apparently, two different kinds of RIB boxes. But i don't understand the difference and I want to figure out which i want.
zz0468
Banned
I'm not aware of any difference in functionality between the two. The 'B' is just a later rev level, so I suppose that would be better. You don't get into any real differences until you get to the smart rib. If you're just trying to program radios, either will work. If you're trying to flash radios, neither will work.
cmdrwill
So Cali
Just differences in the construction, type of componets and housing for the RIB. Some older RIB's do not have the battery option but do have the power jack for 12 volts.
Factory RIB's do have problems on some computers as the RIB does NOT follow the RS232 standard.
Updated road map here: http://batlabs.com/images/rib_mod.jpg
Notice the component value changes and this one has a standard DB25 connector going to the computer.
KD4VEG
The RLN4008, RLN4008A and RLN4008B all have "through hole" mount components and can usually be repaired on a bench. I don't know about the RLN4008C. The RLN4008D and later are all surface mount components and are pretty much, non field repairable.
