RMN5065B Microphone Question
Dolf
Springfield, Virginia
I'm trying to program a XPR4550 with a RMN5065B IMPRES Keypad Microphone to use for amature radio. The mic has 3 buttions on the side. I was successful in programming the purple button "no dot" to change the zone, but I cannot program the "one dot" and "two dot" buttons for the channel up and down. The drop down menu doesn't show channel up/down, but it does show up in the explinations down below. I would think that channel up/down would be a good feature for that mic to have. Do I have another part of the program set up incorrectly, or is channel up/down not programmable for this mic. Thanks for any help.
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
Do you have channel up/down assigned to another button/switch combo? Motorola radios will generally take an option out of the lineup once it's been assigned a button/function.
Regards,
-Frank C.
Dolf
Thank you for responding. I do not have them assigned to any other buttons on the mic, but of course there is the dedicated channel up/down button on the radio.
KG4INW
Midlothian, VA
I just opened an XPR4550 codeplug as well as one for an XPR5550e. It's not an option for the 4550 but is for the 5550e (and non-e models). Unfortunately, the help explanations in the lower pane cover all possibilities for all models without making that very clear.
Dolf
Thanks KG4INW. That makes sense. I guess I'll just switch back to the standard mic. It would have been a nice option for mobile operation.
KG4INW
Midlothian, VA
You're welcome. The newer generation radios very often have nicer features or more flexibility than the previous ones.
