RNC Online Feeds?
Utah_Viper
North Muskegon, MI
daedalus
Bolivia.NC
I'm afraid I am being even more dense than usual.
I went to http://hugoscanner.no-ip.info:8000/ and saw the status page. At present it indicates it is up and running and has 32 listeners. How do I make it 33?
I tried clicking on the "listen" tab and on the stream URL http://hugoscanner.no-ip.info:8000/listen.pls
Apparently they link to a .pls application. What is .pls? How do I listen to it? There is no application on my system that knows how to handle .pls
Thanks!
EDIT: Just noticed all of the links on the status page have no IP address. Is this just a preview page?
wogggieee
Hugo , MN
Thanks!
Download Winamp and use that. Should work. Just tested it and it works for me. I believe it should work with media player as well, but i haven't tried that.
From what i see the peak users has been 1, so you shouldn't have any problem getting a spot.
daedalus
Bolivia.NC
Thanks, Matt. WinAmp did the trick.
And -- obviously I read the status screen wrong - 32 max listeners, not active!
Jack
wogggieee
Hugo , MN
That's too bad that you can't have it going for people to hear. There has been lots of action since about 5:00.
Well there were some "issues" and we'll just leave it at that. My regular feed will be back up at the same address in a day or two.
