Robotic dispatch system in CT
7adem16
CT
Who knows of any Department that use robotic voice to speech in CT. Please Help!
BabaDude77
Connecticut
ur20v
The Feds say my name hot like when the oven on
NOVA
Not CT but I know Northampton, MA, also uses a synthesized voice dispatch system. First time I heard it I thought it was so odd...
cg
Connecticut
Are you looking to ID a channel or simply looking for info? The automated voice works on VHF or UHF or 800, analog or digital, trunked or conventional, it is simply an add on to interface between a computer dispatch program and a radio system.
ems170
Connecticut
In UHF, Fairfield is running it in test mode and Westport has a UHF simulcast of the trunked system. Where are you hearing it as that will help narrow it down?
7adem16
CT
What about any UHF no trucked that is using it? ANY WERE'S IN CT!
ems170
Connecticut
Fairfield is running it on low power not over their dispatch channel yet on a UHF analog channel. They should be cutting it over in the near future.
Westport is running it on a UHF conventional p25 simulcast of the trunked dispatch TG.
garys
Texas
These are computer based systems and can be ported to any radio system if desired. They are actually designed for station alerting and don't have to be broadcast over the radio. When Boston implemented their system with the then new CAD system the plan was to stop broadcasting alarms over the air.
That was changed and the alarms are now broadcast.
In various parts of the country I have used allocution systems used on conventional, trunked, analog, and digital systems.
