soundchaser
I'm missing Kurt's Rocky Mountain National Park online feed this morning. He had all the federal fire freqs on that. USFS freqs are pretty weak and scratchy up here.
Kurt has received approval and his USFS feed should be back up this afternoon.
Jim<
well guess Im just
Ill see what he feeds and see what else I can
since I got it out and set up Maybe Ill do the boulder city/county fire
and PD:roll:
Morse code ID every thirty and simplex.Plan to support the following:
boulder PD "White" = park officers, 154.980 (actually entertaining at times)
This channel is narrowband and will have low audio on older scanners that do not have true narrowband capability.Boulder FD "Dispatch" = 151.3775
This is the INPUT to the 151.3775 repeater.Boulder FD "Fireground 1" = 155.4375
This channel was tried and not used due to co-channel interference from Loveland city services which is no longer the case. The FD uses RED-2 154.205 (wideband) simplex for fireground ops.Boulder FD "Fireground 2" = 158.7525
Hmm.. forgot about the IDs. Those may get to be too annoying. Haven't monitored it since last summer. Will keep track of it on the side as the weather continues to improve to see if the entertainment value is still there or not.Morse code ID every thirty and simplex.
I think the WinRadio will manage it OK. NFM andwidth can be pulled down to 6KHz if need be. Nice to have software definable hardware! So far, it sounds OK.This channel is narrowband and will have low audio on older scanners that do not have true narrowband capability.
Interesting. Having never listened to Boulder city's FD, did not realize that the calls on RED-2 weren't County. Guess I was listening to them after all. Will make that switch.This channel was tried and not used due to co-channel interference from Loveland city services which is no longer the case. The FD uses RED-2 154.205 (wideband) simplex for fireground ops.
