I need to put up a tower about 40' high in a field to get wifi signal for Internet connectivity. I have 50 feet of Rohn 20 that was basically given to me. The base is on a hinged plate. I can't find anything for official specs for the 20, I assume because it's such a lightweight tower not intended for freestanding.
So, questions:
1. Can I install this with the hinged base bolted to studs in concrete then walk it up with 4 sections (including the base)? Not really excited about the idea of trying to climb this thing . How much concrete should I pour if this is the case?
2. Can I do this freestanding? Or, will I need to guy it?
3. If I need to guy it, does anyone have specs on the height(s) to guy it, and the distance from tower base and length of the guy wires?
4. Specs on the size of the guys?
5. What if I just did 30' (3 sections) instead of 40? Would that change anything?
I know I'm probably going to be told to invest in at least Rohn 25 instead, but would like to make use of these Rohn 20 sections if I can. The only thing that will be on the tower will be the 3.65Ghz Wireless radio that I'm guessing weighs 10 pounds max and is about 12"x18"x6" or so.
Or even better, if someone has a spec / install sheet they can guide me to for Rohn 20 them I'll work it out myself.
I appreciate the help in advance!
So, questions:
