If you were local, I'd offer to do it for you, but I'm on the opposite coast.
Having a shop do it comes with some benefits:
They will have the right tools and knowledge.
They'll route the cable well.
They should cut the coax to length. (Less coax, less loss)
They'll install the coax connector of your choice. (avoid unnecessary connections/adapters/failure points)
If you bring the antenna with you, they'll probably even sweep it for you to confirm proper operation.
In the end, you'll be happier with it. You'll know it's installed correctly and you'll never have to wonder if it's done right. The performance and comfort of knowing you didn't cut any corners is really nice.
