Roseville Plane Crash from 2006
scannerboy02
NTSB Identification: LAX06LA110.
The docket is stored in the Docket Management System (DMS). Please contact​
Records Management Division
14 CFR Part 91: General Aviation
Accident occurred Sunday, February 12, 2006 in Roseville, CA
Probable Cause Approval Date: 7/25/2007
Aircraft: Carpenter BJ/Carpenter SA Glasair II-S FT, registration: N540FT
Injuries: 3 Fatal.​
The aircraft was performing low level aerobatics over a residential area when it stalled and crashed into a single family residence. The accident site was located 2 blocks from the passenger's residence. A family member of the passenger stated that they heard the airplane pass overhead, but when they got outside the airplane had disappeared. They heard it approaching again but it crashed before it arrived over the house. Two pilots who were located at the departure airport spoke with the aircraft occupants shortly before the aircraft departed on the accident flight. The witnesses said the passenger told them that he and the other pilot were "going to show you guys what flying is about." Several of the witnesses were on a nearby golf course and other witnesses were in the residential area surrounding the accident site. All of the witnesses said the airplane was performing aerobatics at altitudes they described as between 200 and 800 feet above the ground. Several of the witnesses described specific maneuvers. They reported that on the first pass the airplane was traveling at high speed and it entered a series of "barrel rolls" before pulling up into a climb and banking steeply to reverse course. On the last pass, the airplane completed the roll series, then it pulled up and began climbing and banking. The witnesses said the airplane then stalled and entered a "nose dive" while it was "spinning or spiraling" until it crashed into the house. Examination of the wreckage found no evidence of a preimpact mechanical malfunction or failure.
The National Transportation Safety Board determines the probable cause(s) of this accident as follows:
The pilot's failure to maintain an adequate airspeed while performing low level aerobatics that led to a stall/spin.
