RRDB Differences
Unidener
Sorry another late night early morning question.....
When I click the RRDB Differences the manual says:
Click the 'RRDB Differences' button.
• After the RRDB Differences window loads, click the 'Get RR Data' button.
• An automatic RRDB login is performed using the same RRDB login credentials from the Import RR window. If an error
occurs logging in then go into the Import RadioReference window and check your credentials.
• After the Differences tree loads, scroll down and look for rows with colors indicating a difference.
After I click RRDB Differences nothing happens....What step am I missing and I've attached 2 pictures just to make sure I'm clicking the correct RRDB Differences
It says:
Nothing happens when I click the red box where RRDB Differences is...
Thanks for any help!
ProScan
Software Provider
Ontario, Calif.
The button is not showing. 2 possible reasons:
1. The system wasn't imported from the RRDB
2. The helper file "RRDB Import.txt" is missing in the ProScan folder.
The button looks like this except this is shown in Dark Mode.
Unidener
Well as usual :cool:
I built the SDS200 on my main PC while working on my room. Looked in the Proscan directory and there is the "RRDB Import.txt".
The scanner has been moved and is connected to another PC so I should be able to just copy the file over to the other pc but still no change AND it does not work on the old Main PC.
Here is where I think I'm doing something wrong......your picture with the RRDB Differences above is different than mine I'm I using the wrong RRDB Differences?
ProScan
Software Provider
Ontario, Calif.
Here's anothe picture. Only one area with RRDB Differences. After copying the file over, try restarting ProScan.
Unidener
OK....got ya....looks like mine but the the "system name" field is not populated.... Until I scrolled through some others and I found one that looked similar and there were some dependencies......so I will say it is working due to your fields being populated my screen looked different and I thought you were in a different screen.
looked so different until you posted the other one with the other tabs.
Sorry still learning....when I have a second....
Thanks as always for your help and greet app!!!!
