RS 197
R
retiredmich
Guest
Friend of mine has a RS 197 BASE that I can not get the NOAA weather frequency to stop scanning in bank 1. I go to bank 1 & search for it & it' not there, only has bank 1 activated. I go to globe & turn off PRI
weather with no help. any suggestions ?
n5ims
Sounds like you have weather scan activated. See page 64 on your manual for details on the various types of weather scanning so you can deactivate the one(s) you have active. If you don't have access to your printed manual, you can access the online version from this page in the RR WIKI Pro-197 - The RadioReference Wiki
R
retiredmich
Guest
did what page 64 said to do, did not help it. Also turned off WX PRI & PRI in global settings & that did not help . What next , may be reset to default & start over ?
DickH
Are there other freqs. programmed in the scanner?
R
retiredmich
Guest
there was other frequency's on bank 1 but did not make any diff. So I programed local FD in bank 2
& turned off bank 1 & it scanned OK !. So I reset the radio back to default & reprogramed it & all is ok now. WEARED !
R
retiredmich
Guest
Thank you , I will keep that in mind. Now I got a problem with the RS 197 volume. I got the volume knob turned up to max but very low volume, is there a volume setting I can adjust ? it's low with or with out the ear jack. Any help ?
