jskimrey
- Joined
- Oct 25, 2004
- Messages
- 12
- Reaction score
- 0
I'm going to be purchasing the RS 20-176 Scanner Antenna and placing it in the attic (for right now; hopefully soon I can mount it on the roof). I'm looking at about a 50-foot run.
I'm going to be using my handheld PRO-95 scanner with the antenna.
Any suggestions on coax cable to use? I'd assume I wouldn't want the RG-58 (due to signal loss), but I'd also assume that I wouldn't want something too thick since it's going to be connected to the PRO-95.
Most of my current listening is in the 400 and lower range (although some 800).
Any suggestions on cabling/connectors? The antenna uses a PL connection I believe. Does RS carry anything that would be sufficient?
If not, there's a local shop that specializes in scanner/cb equipment, etc. that might have something.
Any advice would be greatly appreciated.
Thanks!
Thanks!
