RS #20-283 or RS #20-043 Antenna Question
ezernie
Which would you buy for best 800 use with Pro91 using as base, fairly large city use area?
scanbc780
Usually Lurking
Maricopa/Yavapai Counties, Arizona
20-043 if you want an outside antenna. This is a good all around antenna. I used to use mine for 800 but I am now using an 800 Yagi since everyting i listen to on 800 is in the same direction.
Otherwise the 20-283 is good for indoors and portable. So its up to you. If you get good reception with the stock antenna then the 20-283 is gonna give you a good boost and getting the outside antenna is just gonna make it even better yet.
If you are getting weak signal alltogeather consider a yagi. The yagi I am using (dont remember which one) is allowing me to pick up 800MHz digital 40-50+ miles away 8) . So use what I said and go from there.
Brian
