RS/GRE 800 MHz Antenna vs. BCD436HP Stock Antenna
UPMan
In Memoriam
Arlington, TX
http://massivelyuninformed.me/wp-content/uploads/2017/06/RS800.jpg
UPMan
In Memoriam
Arlington, TX
The stock antenna is baseline (i.e. all values normalized to 0). The graph shows the performance of the RS800 as compared to the stock antenna.
rbrtklamp2
Dupage County, Illinois
What brought this up ibhave always found the stock antenna to adequate on both the 325 and 436 line of scanners in fact I usually prefer the stock antenna. Only antenna I've seen work a little better than stock antenna across the board is the Watson 801.
Sent from my SM-N910V using Tapatalk
jonwienke
More Info Coming Soon!
VA
The Diamond RH77CA is significantly better than stock on most bands.
n3ouc
Macungie, PA
Im a little confused. Does this not prove what most people have been saying and that is the RS/GRE 800 antenna is better on 700/800 MHz than the stock antennas? I did not see anyone claim that the RS/GRE antennas are better on VHF or 400 mhz.
Mike
greggk
York,PA
Mike
Confused as well. I bought the RS 800mhz for ALL my portables. Does this graph show that the RS 800's are better than the stock? Everyone can LOL about this question...but I'm really not a radio tech so don't know what this is saying. THANKS. Greg
UPMan
In Memoriam
Arlington, TX
Where the line is > 0, the RS800 is better. The further above 0, the better. If the line is below 0, the RS800 is worse.
greggk
York,PA
Thanks Upman. I assume that the numbers along the 0 line are the frequencies. I appreciate the reply..and the good info. Greg
jonwienke
VA
I would like to see a similar comparison to the Diamond RH77CA.
greggk
York,PA
Correct. From 20 - 1200 MHz. I tested at 5 MHz intervals.
Again, good stuff! Its nice to know that the money I handed over for these was not wasted. All the RS Stores around me are closing...they had one 800 MHz antenna on the shelf and I bought it. I don't need it...but I bought it. Thanks Upman! Greg
