Could you provide a link to the lithium ion batteries that you are referring to?
I don't use li-ion, I use these,
http://www.amazon.com/Powerex-2700mAh-Rechargeable-Batteries-holder/dp/B000FOV92E
73,
n9zas
Which rechargable Li-Ion batteries are 1.2V?most LiIon AA batteries are rechargeable (not all), put out about 1.2 Volts DC
None of those are Li-Ion. None of the Lithium cells are rechargeable.
Are you sure? these have been out for awhile now.
Check these out....
73,
n9zas
Check these out....
Panasonic 3.7 Volt 2350 mAh Li-Ion 18650 Rechargeable Battery
73,
n9zas
Then make sure you turn OFF the charge feature in your pro-106 as another poster suggested, so you don't toast your batteries AND radio!
73,
n9zas
No.
Why would you use the yellow holder, if you don't want to use the 106 as a charger? The yellow holder is for charging batteries and the black one is for batteries that you don't want to charge. You can put rechargeable batteries in the black holder if you don't need to charge them.
Absolutely not true with the OP's Pro-106 and the other GRE-made scanners that I'm familiar with.. . . The radio must be turned on for the charging to be done, therefore with the radio turned on and the batteries being charged the battery . . .
The main reason that you don't want to use the Lithium Ion battery in your battery holder is they are too long, also despite the voltage difference. The normal Alkaline, NimH and Nicd battery is nominally 51mm in length while the Li-Ion is 65mm in length. Lithium Ion batteries require a totally different sensing circuit from a NiCd or NimH. You can't charge a Li-Ion battery with a NimH charger either.
You also don't want to charge any batteries in the radio for various reasons, mainly because there can be problems developing when left unattended (read:explosion). The radio must be turned on for the charging to be done, therefore with the radio turned on and the batteries being charged the battery charging time will be extended, thus causing the battery lifetime to be compromised. Batteries must be charged properly, they must be dead to be charged properly. I know someone will dispute this, but the proper way to charge batteries is in an external charger, not in the radio.
You really have to get at least another set of the same type battery, namely the NimH and a quality NimH charger so that you have always got a good set ready to go when the scanner tells you it's time to replace them. I always go with the batteries up until the scanner displays that the batteries need replacing or charging. This gives the batteries a better charging cycle. Remember how much you invested in a scanner and how you don't want to have to shell out money for a new scanner should there be a major malfunction.
I know this is an old thread but for readers searching I thought it would be helpful to note that it is prudent to test the output with a meter to know exactly what the output is at each setting. Often times the output voltage does NOT match the switch settings.I do charge them in the scanner but have a variable voltage input that I set at 7.5 volts. Keeps teh batteries charged but not hot. They did get rather warm with 9.0v.
