chadbyoung
I just picked up a used RS Pro-94A (No PC/IF) from Ebay. After clearing the memory (resetting) I cannot select a "trunking type" (i.e. EDACS). Following the manual and/or the RR simple guide yields the same result - I cannot select the type of trunking system that I want to follow.
Press "MAN" then
Press "PROG" then
Press "Trunk" then
Select Bank "1" then E
*** Here is where the issues starts***
After this I am supposed to select the trunk type that I want to follow, however the scanner skips this option and moves directly to the step where I enter the freqs.
Any idea what is wrong?
Also, I cannot access the preset search bands (i.e. air, ham, marine), but I can access the preset weather channels
Other than this the scanner works fine
, I mean it picks up freqs when I manually enter them.
Thanks in advance
Press "MAN" then
Press "PROG" then
Press "Trunk" then
Thanks in advance
