Rs pro 96 help
mstevens0510
Canal fulton ohio
I was wondering if anyone has the 1.3 update for the 96. I live in ohio and 1.4 makes the marcs system go silent. Factory 1.1 has the digital noise at beginning of transmission. Any help or direction is appreciated.
Nasby
Ohio
If any of the MARCS sites you are monitoring use 700 MHz control channels the PRO-96 won't track them. No matter what firmware you use.
Swipesy
Northern Ohio
I have it but since you block private messages your out of luck.
Nasby
Ohio
I'll bet he just doesn't have enough posts yet to receive PM's.
I think you have to have 5 posts before you can receive or send PM's.
mstevens0510
Canal fulton ohio
The channels I am trying to follow are
System Name:
Canton/Stark County
Canton, OH
County:
Stark
System Type:
Motorola Type II SmartZone
System Voice:
Analog and APCO-25 Common Air Interface
Last Updated:
November 6, 2016, 7:00 pm (Updated Function Tag assignments for 1 talkgroups(County Police Departments))
specific talk groups are 17744 and 17808. . I only programmed the red primary control channels . I just downloaded the version 1.3 dsp so I am going to see how that will affect it.
Nasby
Ohio
Your PRO-96 should be fine on the Stark System.
Just make sure you setup the rebanding tables for an 800Mhz rebanded system.
