RSPdx DMR / NXDN?
RRR
OFFLINE
USA
What is the easiest way to get DMR and NXDN digital reception from the RSPdx unit?
I didn't know if there were additional software I had to buy, or other add-on
RRR
OFFLINE
USA
Do I have to do all the "virtual audio" and so forth?
wgbecks
NE Wisconsin
No, you don't need to use a separate receiver and virtual audio cable. You can use a single SDR dongle with FMP24 that comes packaged with DSD+ Fastlane.
RRR
OFFLINE
USA
I am referring to the RSPdx unit specifically though. Could it be done without "virtual cable" via RSPdx?
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Not to my knowledge. Not sure how it differs from the RSP-2, RSP-Duo, etc (both of which I own) but you need to pipe audio thru a virtual cable for both of them for a clean reliable decode
  • Like
Reactions: RRR
RRR
OFFLINE
USA
So from the SDR software, I have to then run it through the DSD software...
Why hasn't someone came up a "do it all" (Analog and Digital) software feature?
EricCottrell
Boston, Ma
Hello,
The current DSDPlus Fastlane partly supports the RSPDx. You run FMPP instead of FMP24. The virtual audio cable is not required as local TCP network ports are used. The antenna port cannot be switched, so use Ant A. There is no batch file to run one receiver (1R) mode with FMPP, so you need to create one with the following line:
FMPP -o20001 -f935.0
This sets the output to use port 20001 on the local computer. Just running DSDPlus will put it into 1R mode. It will look for a local TCP connection on port 20001.
73 Eric
