RSS archive help
Anderegg
Enter text in this field
San Diego
Maxtrac RSS...when I try to save my codeplug after reading the radio, I change the archive to C:\mrss\maxtrac, it asks me to give the radio an identity name, but then it says s/n not in archive and archive not saved. Not sure if I need to configure the archive first in another menu, like where you set the COM port?
Paul
Anderegg
San Diego
That's what i do, and that is when the errors show in the upper right corner area. I have also had the same issue in the past with Spectra RSS. When I do go to the save screen, the archive path always says ARCHIVE, and I always change it (F2?) to just a path that exists, even c:\ doesn't save.
Paul
Anderegg
San Diego
I am using DOS 7.1, the "aftermarket DOS", but this issue even happens on Windows 98 SE boot to DOS real DOS. Is there something special about what can be sued as an archive? I just assumed I could point it to the folder where the exe resides.
Paul
