SDS100/SDS200: Rssi d error and noise
Whospoonbill
Damn yeah it didn’t upload what are good d error number and noise numbers
Ubbe
Stockholm, Sweden
D-error should be 5 or lower. Noise detects data as being noise so can't be used for digital signals. And when someone talks on analog channels it also goes up in numbers. But if you manage to look at the value when there's a pause in the transmission but still sends out a carrier it should probably be 500 or lower when regarded as a really good signal. When the numbers go up in 2000 without modulation then it's probably very close to the squelch level.
/Ubbe
Whospoonbill
I’m able to open it I’m on gatrrs on 820s antenna squelch 1 I tried 15 but I know the sds100 can handle 1 even 0
Whospoonbill
Is that normal there a certain part of the city where I get terrible signal there building a bunch of stuff I don’t know if that’s the problem there a lot of concrete buildings around there as soon as I get away from that area it gets better or down the street. I wonder if the fire department has the same issue to and the police
Whospoonbill
It got up to 80 d error once and drop a call when at a certain restaurant otherwise when I went past it it was fine
Whospoonbill
Also I just put the stock antenna on and than swap it with the remtonix antenna and I’m getting better rssi it’s in the 50-40-70 so I don’t know if this new radio needed the stock antenna pro be setup first
