RSSI indicator on ASTRO XTS 1500 handheld
orte
Hi.
Does anybody know how to get or activate the RSSI (in db?) in the display of an XTS1500 handheld?
orte
Thanks. Now I know it can be done. Yes, it is a trunking radio. Do you know the parameter name in the Motorola software that turns it ON OFF?
Jay911
Bragg Creek, Alberta
It's not in dB as Mike said, but you want to put the "RSSI" menu option on a button. Look in Radio Wide>Menu if I recall correctly.
orte
Bad luck. I've looked in the ASTRO CPS software (R20.00), and RSSI is not in the assignment for buttons or switches. There is a "menu" thing in Radio Wide/Display/Menu but I don't see RSSI anywhere. I've found some numerical values for RSSI (they recommend not to touch them) but I cannot find how to put the RSSI (4 bars) on the display.
Did you mean to look in the Flashport (operating system) software?
mikewazowski
Staff member
Central Ontario
RSSI typically shows when you have a SITE button programmed.
As for the signal strength on the display, are you on a trunking system and are you a user? That display is only available when you're sitting I a trunking system.
Jay911
The bar display I don't know about; I was referring to the SITE function (I'm not near my programming computer right now). Pressing the button once will show you your current site and the RSSI value. Holding the button down past the 'long press' duration forces a spectrum wide CC scan (IIRC).
orte
I got it.
This is what I did:
1 read device
2 go to trunking system-1
3 go to General
4 go to Coverage type
5 select SmartZone (instead of None)
reprogram radio
Now it always shows when turning on the radio
orte
two more things:
I can get a numerical RSSI in dB by programming a button with "Site Displ/Srch" option. When I pres the button, the display says something like RSSI 69 (or a similar number)
But a bad thing is that now I cannot TX. I receive fine but I cannot talk. but if I put the "Coverage type" field back to Disable (from SmartZone), then TX works fine again. Anybody knows whats going on?
mikewazowski
Staff member
Central Ontario
two more things:
Once again, no you can't. That number is not in DB. It's in some arbitrary scale that Motorola has chosen.
kb0uxv
Minnesota
Do you need to click the "site alias" box under TRS and then populate that list with some data in order for this to function when not set to smart zone?
Site Displ/Srch is the correct button for RSSI on a portable, press and hold to jump to another site. In my experience the numbers are in the range of 0-160, and anything better than 40-50 is normally reliable for talk out. I have never scene any tables that compare the Motorola scale to dB, dBm, etc.
With that said if the radio is only being used to scan a system then these buttons should have no function, if you can use that button and can see site data then you have affiliated and will cause harm to the radio with your fraudulent ID, and are probably commiting a criminal offense in your state. It looks like Orte is a valid system user since he depends on transmitting, but I wanted to throw that in for others using XTS as scanners.
