Is anyone having trouble with the RT Systems programming software for the Anytone 578? When I click on Settings>Radio Menu Settings the AT-D578 Programmer shuts down instead of opening the Radio Menu Settings window…
RT Software often leaves a lot to be desired. Quirky and limited.
So what is your suggestion in lieu of RT Systems? Personally, I haven't found anything better for the radios I have, which are pretty much all Yaesu. I've tried the free Yaesu programming software for some of my radios and it's junk compared to RT, which I have NEVER had a problem with.
NEVER had an issue with RT Systems, Inc. software. The support staff is among the best I've ever worked with. A++++++
Ok. That link seemed to work for me. Currently awaiting their reply…Just send an email to techsupport@rtsystemsinc.com and describe your problem.
Long time RTS user across many radios.Ok. That link seemed to work for me. Currently awaiting their reply…
I gave up trying RT’s email and phoned them today. It seems they were made aware oIs anyone having trouble with the RT Systems programming software for the Anytone 578? When I click on Settings>Radio Menu Settings the AT-D578 Programmer shuts down instead of opening the Radio Menu Settings window…
RT had corrected the glitch in their software just after I noticed it last week. I simply had to update the software and can now see the pop-up window for Radio Menu Settings. Thanks all for your help! I’d like to chose out this thread but haven’t found where to do that…Long time RTS user across many radios.
Last I looked many months back DMR radios were not on their agenda. Maybe you found a "bug".
A few programming software packages require reading the radio first.
Is your 578 model a match to their compatibly list?
I have found the typical Anytone radio firmware and CPS have to be in lockstep with each other. Usually because radio menu setting in the firmware change and the older version of the CPS does not know how to deal with the additions. My comments based on moving thru the many 868 and 878 firmware changes over the years. RTS was not a player at the time for Anytone DMR.
Let us know how it is resolved.
Mike
Click on "Report" and make the requesthaven’t found where to do that…
