From the video description: Dynamic frequency correction (in Hz) is displayed in spectrum window titles.
I see it now. There is so much going on, it's hard to tell where everything is. I was looking in the main window for it.
When the PPM value is set 10 below the correct value, the tuning eventually warps by 8 kHz to get back on center. Dongles drift slowly, so TRUNK88 corrects slowly.
Yes, too quick and you would run into problems with interfering signals throwing things off, or short reception nulls.
That generally works for me, but for some users, it doesn't. With a laptop or netbook, I could see where a dongle plugged in near the CPU fan exhaust holes could be affected when the CPU load goes ballistic (hello SDR#...)
So, is there any work on an SDR# plugin for AFC (which is what you've really added here). Wow. I bet I haven't used that term in a decade.
Some users have reported that wrapping the entire dongle exterior in foil greatly reduces drift. Not something I'd want to do or have had need to do.
Of course it does. The whole dongle is effectively a TCXO of a sort, so any additional 'insulation' will raise and stabilize the temperature at which it operates. Stick the thing in a piece of foam for better results.
Of course, I always wonder about that, as components and heat are mortal enemies.
Not really. TRUNK88 adjusts in 200 Hz steps, while at 800 MHz, a change of one PPM is over 800 Hz. Adjusting PPM will not center the demodulated audio - it will have a noticeable DC shift.
Agreed... shift to the tune of up to half a ppm.
What is the maximum compensation you've programmed in?
Also, is 200 Hz steps a set value, or is it 200 Hz steps at 400 MHz (or something like that)? IOW, is it truly Hz steps and not ppm calibrated steps?
When monitoring a single system, like a Moto TRS or a NEXEDGE TRS, I assume that all of the site transmitters are running off of the same reference oscillator, so not an issue. Also, nothing says that a fine tuning system can't maintain a per-channel correction factor to handle off-frequency transmitters. And I've rarely seen such transmitters, so not really much of a concern.
Much of my monitoring involves multiple systems (mostly non-trunked), so I don't have that benefit.
Thanks for the replies. Oh, and is this a feature of the current release version?
