RichM
- Joined
- Jul 22, 2004
- Messages
- 69
Using blog V3 w/sdr# & fast scanner plug-in on an outdoor wide band antenna with an older windows laptop duo core. I‘m running a powered antenna splitter and the signals coming from it are identical when I use 2 hardware scanners. On civilIan air it works flawlessly, I can search the entire band in less than 2 seconds easily beating my Pro197. With detect set at 150 it catches everything every time. Detect at 120 it starts to miss some.
Completely different on mil air, it will skip right over strong active freqs. I can get a 5 bar signal on the Pro197 and the dongle will skip right over showing nothing. With detect set at 200 it will start to catch some of the stronger signals but still miss a lot that the scanner is picking up. Raising the detect level slows it down a lot and kind of defeats its purpose of lightning fast searching.
I can manually enter known active mil air freqs and hear and see them just fine, but when it searches 225-380 it’s seems to lose its sensitivity. Also I’m in a rural area with little interference and close to the action (30 miles from the bombing range, I routinely get 5 bars on my hardware scanners).
I‘m at a loss for a solution since it works perfectly on civ air. The only difference I notice is that the noise floor seems more “active“ in the mil air band. Would a better unit (considering an Airspy mini) possibly have better sensitivity in this band? Perhaps better filtering against the rather active noise floor? It’s definitely not the antenna as my hardware scanners have proven. Not sure what else to try. Ideas/suggestions welcome, thanks.
