Hello All
I have recently purchased RTL-SDR V3 along with a cheapish dipole antenna for use at home. I am very new to SDR but I have used a handheld scanner for a while now. So please forgive my ignorance on this topic. I am trying to listen to aircraft on the civil band.
The problem I am having is that when I am picking up audio transmissions the voice is very clear but its almost drowned out with noise. I have a small handheld Uniden UBC125XLT with a Watson W899 on the window and its picking up the same transmission very clearly.
I am using the Airspy Sharp software. The waterfall is yellow/orange with a clear red line when the aircraft is transmitting. The legs on the antenna are extended to 60cm each. I am listening on AM with a bandwidth of around 15000, order of 1000 and the RF Gain Set to around 33dB.
Any Help with this problem will be greatly appreciated.
