I'm just beginning to play around with a couple of ADS-B programs; Dump 1090 and RTL 1090. I've gotten both programs to work, but a question: How do I set my R820T dongle's PPM correction factor in RTL1090? (It's version 3.0.4.161)
My dongle PPM correction factor is 54. I thought there should be a command line parameter to set the correction, but I can't find it mentioned in the online manual.
BTW, the online manual seems to be written for an earlier version, and as such there's a few differences in the instructions for the older interface vs. the new one.
No, I'm not using Virtual Radar; I had briefly experimented with it, as well as RTL1090, a long time ago, but I got sidetracked with other interests.
Thanks for the input Steve. I am now wondering if an amp would offer me much benefit, as my total run of coax will only be around 20 to 25 feet. I will be using Belden quad-shield RG-6 cable, and a Max System 800MHz ground plane antenna modified for 1090MHz.
