RTLSDR-Airband [R82XX] PLL NOT LOCKED! error
Andy2712
Lombard, IL
So I've been playing with this the last couple of days trying to get it up and running. I had some brief success yesterday afternoon, but somewhere along the way something got broke. Every time I run the program I keep getting an [R82XX] PLL NOT LOCKED! error. I've surfed around and can't find any way to fix this. I've tried messing with the correction and nothing is working. This dongle I'm using is a Nooelec SDR and like I said it was working for a bit yesterday but now something is wonky. Can anyone offer some advice or suggestions?
Reconrider
Inside the Galaxy
Radio Galaxy
No idea how to use the noelec’s, but if it has a different driver, did you run the program as admin then install the new driver?
KE5MC
Lewisville, TX
No experience with that hardware but...
In a typical radio using a Phase Locked Loop(PLL) built with a number of discrete parts and having an adjustment pot you have a shot at repair. Or at least an adjustment to bring the correction voltage into the input range of the PLL. Only thing I can think of is messing with the correction offset might have gotten things way out of wack. With the hardware integration of the SDR in a Dongle you don't have much to work with and they run hot. To the point some come with a metal sleeve and a thermal pad on the hot parts to make contact with the sleeve. Your dongle may have given it up forever... I would try to get the correction offset back to original value most likely zero or near zero and see if that help.
Good Luck
Mike
air-scan
Either software or failing hardware. Email Nooelec support. Requesting Technical Support – Nooelec
You might be eligible for a warranty replacement.
