As others have said, most amateur radio RTTY uses 170 Hz shift between the Mark and Space tones. But, non-amateur radio users may be using other shifts.
If you haven't already, I suggest you go to the Icom website and download both the Basic and the Full manuals as PDF files. You can use your computer to search for things in the PDF manuals rather than flipping pages in a paper manual.
In the Set Menu of the radio in the Function category, you'll find the RTTY Mark Frequency (defaults to 2125 Hz) and the RTTY Shift Width (defaults to 170 Hz). The RTTY Shift Width can be changed to 200 or 425 Hz in addition to 170 Hz. But, there's a catch. The internal RTTY decoder in your radio only works when the RTTY Mark Frequency is 2125 Hz and the RTTY Shift Frequency is 170 Hz. This is a limitation in the Icom firmware that you can't get around. Your only option would be to use your computer to decode the signals using a RTTY decoder such as MMTTY or FLDigi.
Baudot RTTY using 45.45 baud is still very popular in amateur radio and there are several RTTY contests each year (most recent one was this past Saturday). But, outside of amateur radio, you may find other speeds and shifts being used as well as other modes that sound like RTTY, but aren't.
