Alas, I am typically a "keep searching, someone has had this problem before," type of troubleshooter, but I'm running low on close matches and even lower on patience, unfortunately...
I have a desktop PC (Acer, if it matters) running Ubuntu 22.04.4 LTS.
I have 3 SDR sticks plugged in; they're all connected to a single USB 3.0 hub, into the PC via 1 USB port (yes, yes, I wanted to fix this piece of the setup, but that's for a different time).
I have 3 instances of op25-rx and 3 instances of op25-liq services running at a time (i.e. op25-rx_main, op25-rx_backup1, and op25-rx_backup2.service, and then the same format for op25-liq_main.service, etc.) This was at the recommendation of Boatbod, who — in a thread here a long time ago — indicated that this was preferred over a single "multi-rx" setup for my particular use-case. It has run for a long time and produced exactly the results I wanted.
Until now. I had a power outage (that lasted longer than my UPS's did, and longer than it took me to get a borrowed generator hooked up).
The "rx" services for "main" and "backup1" are fine, but the op25-rx_backup2.service fails.
Checking the particular stderr output (here, it is stderr.3), I get:
Previous threads related to similar "usb_claim_interface" errors suggested checking my "blacklisting." First, I confirmed the file exists:
Then using nano to check the contents, I've got:
I've attempted to restart the processes individually and in a single "systemctl restart" command, to no avail. If it may be of note, the op25-liq_backup2.service is running without issue, producing a completely empty recording file.
What is my next step in this process, please? Thanks in advance!!!
Code:
myname@scanner-desktop:~/op25/op25/gr-op25_repeater/apps$ sudo systemctl status op25-rx_backup2.service
× op25-rx_backup2.service - op25-rx
Loaded: loaded (/etc/systemd/system/op25-rx_backup2.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2024-11-03 18:08:50 EST; 20h ago
Process: 257647 ExecStart=/bin/bash -- op25_backup2.sh (code=exited, status=1/FAILURE)
Main PID: 257647 (code=exited, status=1/FAILURE)
CPU: 1.398s
Nov 03 18:08:50 scanner-desktop systemd[1]: op25-rx_backup2.service: Scheduled restart job, restart counter is at 5.
Nov 03 18:08:50 scanner-desktop systemd[1]: Stopped op25-rx.
Nov 03 18:08:50 scanner-desktop systemd[1]: op25-rx_backup2.service: Consumed 1.398s CPU time.
Nov 03 18:08:50 scanner-desktop systemd[1]: op25-rx_backup2.service: Start request repeated too quickly.
Nov 03 18:08:50 scanner-desktop systemd[1]: op25-rx_backup2.service: Failed with result 'exit-code'.
Nov 03 18:08:50 scanner-desktop systemd[1]: Failed to start op25-rx.
Code:
myname@scanner-desktop:~/op25/op25/gr-op25_repeater/apps$ cat stderr.3
Using Python /usr/bin/python3
gr-osmosdr 0.2.0.0 (0.2.0) gnuradio 3.10.1.1
built-in source types: file fcd rtl rtl_tcp uhd hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
Using device #2 Realtek RTL2838UHIDIR SN: 00000001
usb_claim_interface error -5
Traceback (most recent call last):
File "/home/scanner-admin/op25/op25/gr-op25_repeater/apps/./rx.py", line 1101, in <module>
rx = rx_main()
File "/home/scanner-admin/op25/op25/gr-op25_repeater/apps/./rx.py", line 1005, in __init__
self.tb = p25_rx_block(self.options)
File "/home/scanner-admin/op25/op25/gr-op25_repeater/apps/./rx.py", line 169, in __init__
gain_names = self.src.get_gain_names()
AttributeError: 'NoneType' object has no attribute 'get_gain_names'
Code:
myname@scanner-desktop:~/op25/op25/gr-op25_repeater/apps$ ls /etc/modprobe.d | grep blacklist
amd64-microcode-blacklist.conf
blacklist-ath_pci.conf
blacklist.conf
blacklist-firewire.conf
blacklist-framebuffer.conf
blacklist-modem.conf
blacklist-oss.conf
blacklist-rare-network.conf
blacklist-rtl.conf
intel-microcode-blacklist.conf
Code:
blacklist dvb_usb_rtl28xxu
blacklist rtl2832
blacklist rtl2830
blacklist rtl2838
