Running two antennas?
BugBite
Hey there,
i have a bct15x I currently have an antenna I got off of eBay for around 20 bucks I get decent range on it I had it out my bedroom window when I was testing it out before I permanently ran the wire through my house and up my attic and putting it on the roof. One of the frequencies that I did get when I was going out my bedroom window doesn't come in that clear now that it's on my roof I was thinking about getting a second and tanner and putting it on the opposite side of the house. Is it possible to run two antennas?
KB4MSZ
Billy
Tampa, Florida
If you can provide a little bit more information about your setup there are those who can help with your situation.
1) The model of antenna you are using
2) The type and length of coax you are using
3) Was the same length and type of coax used in both of the antenna positions?
4) What frequency was involved in this particular test case?
5) Did the test frequency happen to be in a direction favorable to the direction the window faces?
6) In the case of two antennas, do you plan to monitor different bands with each or are you wanting diversity on the same band?
Oh by the way, welcome to the forum.
