Rutherford County TN, La Vergne/Smyrna?
Kubbie
Middle Tennessee
I have the La Vergne/Smyrna analog and the P25 Middle TN Trunked Radio System programmed in to scanner but never seem to pick any transmissions up for them. Anyone in the area have any luck picking these transmissions up? I get Murfreesboro police and fire okay so something is working at least.
jpryor
Nashville / Green Hill TN
Smyrna is currently active on the TACN Smyrna site. Their primary dispatch channels are P25 Phase 1 FDMA digital and not encrypted. Recent upgrade to Smyrna PD has moved some of their back channels to P25 Phase 2 TDMA digital and encrypted.
La Vergne is currently active on the TACN Antioch site. Their primary dispatch channels are P25 Phase 2 TDMA digital and not encrypted. Their remaining channels are encrypted.
For La Vergne, be sure you are using a scanner that is capable of P25 Phase 2 TDMA digital, as some of the older digital scanners only work with P25 Phase 1 FDMA digital.
Eventually I expect the Smyrna site will be opened back up again to other users and La Vergne users as well. La Verge added more frequencies to that site and it was upgraded to also be Phase 2 TDMA capable. Right now the Smyrna site is not showing any other 700/800 TACN peer sites, and no longer carrying other state traffic like THP.
Kubbie
Middle Tennessee
Thank you. I do have a P25 phase 2 scanner. Do you happen to know where the frequencies are at on here so I can look them up on Sentinel to add them to my scanner?
All the ones I currently added do not appear to work. Below are the ones I found here.
Rutherford County - LaVergne Talkgroups
DECHEXModeAlpha TagDescriptionTag
3089c11DLavergne FDLaVergne Fire DispatchFire Dispatch
3093c15DLaVergnePD 1LaVergne Police DispatchLaw Dispatch
3095c17DLaVergnePD 2LaVergne Police SecondaryLaw Tac
3097c19DELaVergnePD ELaVergne Police - EncryptedLaw Tac
3099c1bDLaVergnePD99Lavergne Police 3099Law Tac
3101c1dDLaVergnePD01Lavergne Police 3101Law Tac
3105c21DLaVergneMALaVergne Mutual AidInterop
TN - Rutherford County (149) - Public Safety Talkgroups
3040076c0DE74-RC-EMACounty EMAEmergency Ops
48161bc21T74-LPD-DISP-1LaVergne Police - Dispatch 1Law Dispatch
48162bc22T74-LPD-DISP-2LaVergne Police - Dispatch 2Law Dispatch
48163bc23TE74-LPD-3LaVergne Police - Channel 3Law Tac
48164bc24TE74-LPD-4LaVergne Police - Channel 4Law Tac
48165bc25TE74-LPD-5LaVergne Police - Channel 5Law Tac
48166bc26TE74-LPD-6LaVergne Police - Channel 6Law Tac
48167bc27TE74-LPD-7LaVergne Police - Channel 7Law Tac
48168bc28T74-LFD-DISPLaVergne Fire - DispatchFire Dispatch
48169bc29TE74-LFD-2LaVergne Fire - Channel 2Fire-Tac
30300765cD74-SPD DISP1Smyrna Police - Dispatch 1Law Dispatch
30301765dD74-SPD DISP2Smyrna Police - Dispatch 2Law Dispatch
30302765eD74-SPD TALK1Smyrna Police - Talk 1Law Talk
30303765fD74-SPD TALK2Smyrna Police - Talk 2Law Talk
303077663D74-SPD-COMMANDSmyrna Police - CommandLaw Tac
303087664D74-SPD- DETECTVSmyrna Police - DetectiveLaw Tac
30318766eD74-SPD NARCSmyrna Police - NarcoticsLaw Tac
303067662D74-SPD SWATSmyrna Police - SWATLaw Tac
303127668D74-SPD TRAINSmyrna Police - TrainingLaw Tac
30315766bD74-SPD-PATCHSmyrna Police - Patch ChannelInterop
303137669D74-SPD EVENT-1Smyrna Police - Special Events 1Law Tac
30314766aD74-SPD EVENT-2Smyrna Police - Special Event 2Law Tac
30316766cD74-SFD DISPSmyrna Fire - DispatchFire Dispatch
30317766dD74-SFD OPSSmyrna Fire - OperationsFire-Tac
303257675D74-SFD CODESSmyrna Fire - InspectionsFire-Talk
303217671D74-SUTIL 1Smyrna Utilities - PrimaryPublic Works
303227672D74-SUTIL WTOSmyrna Utilities - Water Treatment OperationsPublic Works
303297679D74-SDPW ROADSmyrna Public Works - StreetsPublic Works
davewhall29
Knoxville, TN area
What you posted above are the talkgroups, not the frequencies you need. At the top of that page of the second picture you posted (TACN) are a list of sites and each site has multiple frequencies. You need to use the Smyrna site to hear Smyrna and the Antioch site to hear Lavergne.
Kubbie
Middle Tennessee
I am sorry, but I am a bit new to the new scanners that use programming. When I add favorites to the Sentinel application, I do not see those frequencies when I select TN - Rutherford County (149) - Public Safety Talkgroups to add to favorites. That list is pretty much all it shows. The software is a little confusing because it is only showing the TGID and not the frequencies associated with them. I feel I am missing a piece of the puzzle somewhere.
Kubbie
Middle Tennessee
I think I may have figured it out. It looks like in the Sentinel software has these as two different entries. One entry for the frequencies and another for the TGID and they do not appear to directly refer to one another by title. That might be what I was being told above, but it was not obvious using the software where or how they were linked together within the scanner. It still is not obvious to me how the scanner uses the two different entries to pull the transmission in, but at least I am seeing the police dispatch 1 for each now. Now to try and figure out how to get the other entries I want in there using this software. Thanks again t those who have replied and were patient with my questions.
jpryor
Ya, the 'sites' with frequencies are after the talk group 'departments'. Those items are both oddly included in the same hierarchy level of the tree. For a trunking system you will need at least one site and one or more departments of talk groups active to scan. Make sure you have at least have the Antioch and Smyrna site included. The radio will scan any included sites for any included groups. Sites can be locked out and if you have location based scan enabled, that can impact the sites that are active.
For ease of use, I generally import the TACN sites and departments that I desire in to a dedicated favorites list.
IE example below with where Antioch site falls in relation to the other items in the tree...
83033
And from the system level department/site detail view...
83034
Kubbie
Middle Tennessee
How do you just import specific departments or sites? The software always seems to pull everything in. It seems it should be easy to highlight and import individual site/departments but it seems to pull everything/all in to the favorite.
jpryor
From the tree, you can right click and append or remove items. From the system list view, you can multi select and append or delete item. Either start with adding all, then remove what you dont want. Or start with just the couple sites and groups you may want.
poospudge
Nashville
For La Vergne & Smyrna, your best bet is just adding Antioch, Smyrna & Tiger Hill sites. I never miss any traffic county-wide
