RVN 4191 Error 2426
gtaman
TACSAT
GALAXY 19 91.0° W
Happend to turn on a CP200 this morning had fun hearing the death beep then a hissing noise. Now I have maybe a new paper weight. Anyways when I read the code plug I get error 2426 I can't find anything about this error. I know that the code plug is bad because its hissing that's a sign bit what's the error. It's an unusual one and can it be corrected by myself or is it taking a trip to the depot?
motomeso
Ontario
Download the tool from MOL to fix the corrupted codeplug which is a known issue for the CP200.
motomeso
Ontario
I don't have access to my MOL right now but I believe the latest version is 5.16. What's the history on the radio?
gtaman
TACSAT
GALAXY 19 91.0° W
Newer radio was used I'm actually doing this for a friend who has a pair of these. Happend to his radio never had problems before. Not last night it had squelch problems rand bursts of static. Battery was low so we put it on the charger. Woke this morning to a bonk tone.
motomeso
Ontario
Well if you can't recover it with the codeplug patch tool offered by Motorola you'll have to depot it or trash it.
gtaman
TACSAT
GALAXY 19 91.0° W
5.07 is about 4 years old.
Time to upgrade.
If the recovery tool on MOL doesn't work, open a case on MOL and send it to the depot.
I have 5.16 haven't had time to install it. For the cost a moto ill just buy another one and use this one for parts.
motomeso
Ontario
Don't give up that easy. I'm sure it's still recoverable.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
The latest is 5.17 which came out right around New Years. The only change from 5.16 is that they locked out 25 and 20 Mhz bandwidths. Without a special entitlement key, only 12.5 can be programmed.
That said, I had what I thought was a catastrophic failure with a CP200XLS. The radio would not do anything but beep at me, and the first read attempt resulted in an error. I pulled a known good codeplug from my archives and attempted to write it to the radio. CPS reported an error and then proceeded to fix the error and finally wrote a good codeplug into it. The radio then performed fine.
I have no way to know for sure, but it's possible that the latest versions of the software are capable of fixing problems like the OP is reporting especially with newer radios. Ours are about 12 months old.
gtaman
TACSAT
GALAXY 19 91.0° W
Ill try it out. The latest I will use is 5.16. I'm not going thru the process of getting the wideband keys from big /\/\.
SteveC0625
IIRC, 5.16 was the version that I was using when I had the failure with the CP200XLS. You should be OK. I can't guarantee that it will fix your problem, but if you have a known good codeplug for that model, you can certainly try to write it into the radio and see how it goes.
gtaman
TACSAT
GALAXY 19 91.0° W
I'll try it.
