Rx frequencies
sjsamuel
I am trying to program a trunked frequency. I'm having trouble with figuring out which control frequency to use or if I should use one of the alternate frequencies. Aldo have having problems locating the correct DPL to use. This is for the Prince Georges County, MD agencies
kayn1n32008
ØÆSØ
Sector 001
Also have having problems locating the correct DPL to use. This is for the Prince Georges County, MD agencies
This is a digital system. It does not use DPL. You require a phase 2(If the talk groups are TDMA) capable digital scanner to be able to listen to this system
Sent from my SM-G870W using Tapatalk
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Thread moved.
I'm thinking that if you're trying to figure out what dpl to use on a trunking system, you probably should have bought a scanner.
clbsquared
Isle of Wight County
If you're trying to use an APX 7000 to "scan" a Phase II system and you don't know how to set it up, your radio will most likely become inhibited by the system administrator shortly after it affiliates to the system. And you will no longer have an APX 7000. You will have a $5000.00 paper weight. Programming trunked systems on a Motorola radio is an advanced level task. Not to mention the fact that there could be legal consequences for doing so and getting caught. My suggestion to you is buy a scanner.
Sent from my HTC One A9 using Tapatalk
