sorry for all the trouble guys i just cant get it ?
I suggest concentrating on getting basic signal decode to work. Worry about the other stuff later. That said ...
i agree ok so how do i get it to decode i tryed other control freq and got the same results, and its strong 99%? i can here it throgh my speakers on the comp its static till some one talks, same sound when i listen to the scanner
Any Motorola or EDACS channel that you know is Moto or EDACS is going to be decoded by UT, whether the system is imported into UT via RR or whether you don't import anything at all. It'll just pop up as a new system and will show info
as far as this doing it all by its self nothing has happend at all so it must not be decoding right?
I know it sounds like a lot to do, but it's a logical next step. When I installed by tap in my 996 I initially did something wrong that ended up causing noise to be induced into the audio as it was fed into the computer and it caused problems - If I touched the ground on the 1/8th jack I could decode and if I let go I got all kinds of crappy noise induced. I forgot what I had done wrong at that time
Manually use Tune to scan between 851 and 868.975 - find some active control channel frequencies for systems you can identify (by ear) as Motorola or EDACS. Find strong ones, that give you a completely strong signal. Do this while your scanner is somewhat near your computer but not plugged into the computer. Note the quality of the audio. then once you hook it back up to the computer listen to hte audio (not through the discrim/sound card but through the scanner's speaker) and see if you notice any change in the quality (decreased sig strength, noise induced) - then monitor the discriminator output for same.
i tryed the sugggestions and it was all the sameno differince at all
and what should the scope look like? and could you show me a good one as a ref for me.
Next step may be trying to record some of the audio (using your computer, maybe the Sound Recorder under Accessories - I thin that is where it is). Record a short sample sound bite, save it, then if you have someplace you can upload it to you should do that and then provide us the link so we can hear it
dont know how to do this
