Saber III flashcode question
Seadoo
Can someone post the flashcode number that is required for a saber III to do digital trunking on 800 Mhz. Thanks
Seadoo
Yes, im sorry, i meant astro saber II. What flashcode number is needed in order for it to do digital trunking on 800mhz. thanks
grem467
Houston, TX
there are a number of flashcodes that are digital trunking enabled, it would be far eaiser to post which one you have and we can tell you what it is.
the rule of thumb i use though, is that if the first digit is ODD then its IMBE.
that should narrow down your search
Seadoo
Thanks grem for that little piece of info. but if you dont mind, can you tell me if this will work for digital trunking .400004-000000-8 for a Saber II Digital portable radio, 800 MHz.. thanks.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
There's an interactive flashcode decoder somewhere on this site.
You'll be able to plug in your flashcode and get it to display what options are installed.
Search around and you should be able to find it.
grem467
Houston, TX
http://www.radioreference.com/modules.php?name=Flash
and here is what it supports:
Options Installed on this Flashcode:
400004-000000-8
H14/G114 Digital ID Display
H37/G50 Smartnet Operation
so yes, trunking.. no to IMBE
smackdaddy
Also, don't forget.. If you are looking to do IMBE, you may also want to verify that the Host/DSP can support that.
There are some Host/DSP combinations dubbed as "Astro Ready" which are lacking the IMBE guts.
Cheers,
SD
