Sac Area Ambulance/Life Flight to Hospital Freqs
mkewman
Sacramento County, California
Does anyone have Ambulance-2-Hospital or LifeFlight-To-Hospital Frequencies?
I've been unable to find any frequencies that are in use. can someone post them for me?
nicklep417
Wayne/Holmes Counties, OHIO
Here in Modesto, I usually hear ambulance-to-hospital on the MED frequencies. I can't say that I've ever heard a life flight-to-hospital transmission on those freqencies though. I haven't heard a life flight-to-hospital transmission on any frequency since I lived in Ohio. That was 3 years ago.
digitaljim6
New Jersey
Unlikely that cellphones are used when airborne. Besides the FCC restriction (47 CFR 22.925 - includes all aircraft types, even balloons), successfully using one while looking down the throat of multiple sites in an area like Sac would be a crap shoot. Doing so interferes with ongoing terrestrial cellular conversations, too.
Interference is the real reason for the FCC prohibition. Airborne cellular ops defeat the entire cellular design philosphy and have well-known disruptive effects on the ground systems and users.
The FAA restriction addresses electronic device interference to aircraft nav systems (14 CFR 91.21). My reading of the FAA regs says that air ambulance companies are required to be licensed as air carriers (they do fly passengers for hire after all), so they would fall under this restriction. Any aircraft flying IFR is under this restriction, whether for hire or not.
As for Nextel, they prohibit airborne use (ask them at 1-800-639-8359) but the FCC rule directly related to their type of systems (47 CFR 90.423) conditionally allows airborne use. The conditions are broad enough to mostly prohibit it due to the interference problems. Airborne Nextel calls would experience interference issues similar to airborne cellular calls - that's probably why Nextel simply prohibits airborne ops.
Some air ambulances use the med nets (463.000-175/468.000-175) for patient info. Some even use their company FM systems and have their dispatchers telephone the info the the hospital. Don't forget Calcord 156.075 for on-scene if you're close enough.
AA6KA
sacramento calif
Lifeflight in Sacramento is no longer in operation as of this year. They used 155.340 Blue med for most helicopter traffic. It is still used U.C. Davis Med center as helo to hospital traffic I.E. REACH, Calstar.
When Lifeflight was operational they also used UCD's trunked radio system for their radio traffic.
UCDMC also uses the Sacramento County TRS for med net coverage. The UHF med net is very seldom used.
digitaljim6
New Jersey
mkewman said:
company fm systems? what do you mean by that?
A "company" channel in an aircraft usually refers to a 118-136 MHz AM aircraft channel. Air carriers often have them for traffic between their aircraft and air bases. I was making the distinction between that and an "FM" system or channel like Sac County trunked, 155.400, etc.
bigRoN18
Roseville, CA
I know that the TRS gets used for reports to the hospital. Dispatch in Sacramento is done via MDCs... they have been changing out their MDTs for MDCs... a WindowsXP-based computer. AMR has completely changed out their old MDTs in their rigs now. Communications between AMR and their dispatch in Sacramento area is via Nextel. I do CCT and my rig has no 2-way radio at all, except for my Nextel portable and the Nextel hardwired in the rig. I have learned that it is nice to use the "old fashion" 3-watt transmitter with a gain antenna (I at least believe I was told it was 3-watt... it is at least a lot better than my handheld.)
Kirk
DB Admin
Relying on Nextel to work in a disaster is extremely poor planning. I'm stunned that they don't at least put a high band radio in the CCT rigs... Anything with a gurney and red lights can be pressed into service during a MCI, and w/o a radio you're asking for trouble.
northzone
Northern California
Back to the original question. I have heard Calstar helos using Med-4 (463.075) to give reports to Sutter-Roseville when inbound.
kma371
Who is it that we hear on 155.295 then? From what I understood, it was AMR. The locations they are giving are in Sac Co.
AA6KA
sacramento calif
AMR Sac
AMR Sac was formerly On 155.265 .However Doug Petrick the wonderful Manager that he is, forgot to re-license the Sacramento frequency. They were litteraly thrown off of the frequency by the FCC. The 155.295 is used for Placer county/Sacramento Metro Fire Contracted units. The BLS/CCT Division uses Nextel. Yolo County uses 155.235 PL 141.3.
digitaljim6
New Jersey
Thrown off by the FCC? They lost the authority to use the channel at their own hand.
That's like saying the hotel stole your money when they kept your deposit because you didn't show up.
You snooze, you lose.
