gsalogar
Saginaw Tones
I heard tones on the MPSCS system, are they still broadcasting tones on 154.2500?
gsalogar said:Anyone know which TG 2655 is? Heard an Alpha unit giving a patient update and was en route from Birch Run area
gsalogar said:I heard tones on the MPSCS system, are they still broadcasting tones on 154.2500?
All talkgroups do not transmit on all towers do they?
Seems like regional TG's would be restricted to regional towers whereas only statewide TG's would go on all towers.
Dispatchers do not have the ability to select towers. That's what is so cool about smartzone. The subscriber just travels, and the system does the rest, lighting only the towers that need to be used for that TG.
Wirelessly posted (MOT-R38.0/00.62 UP.Browser/6.2.3.4.c.1.123 (GUI) MMP/2.0)
1694 is albee fire admin tg and 1749 is albee fire ops tg. Each twp fd @ this point has both a admin & a ops tg.
This is a good tip, each township fire having a Admin and a Ops TGID. If you take the old alphabetical list of those fire departments and, knowing some of the new Admin and Ops TGIDs, I believe you can extrapolate the new TGID's for them all. The only hole in this is a skip around MBS, but I think that MBS may be using some or all of 1707 thru 1709. I wonder if this tactic would work for other services?
I was just on the mpscs database page and they have a lot of new info on Saginaw County. Looks like almost everything is listed.
What it looks like they did was put all the Townships in Alphabetical order for both Admin and Ops, and then assigned TGID's in numeric order for both, Almost.
I pretty sure based on some communications I've heard so far is that 1707 is MBS International Airport. I'm also sure that it's an Admin. Question I have is, is it Admin for All Airport Ops (which I'm leaning towards). Or Admin for CFR. 1708 or 1709 is prob an admin for Richland Twp Fire. However, that is unconfirmed.
