Saia Tier 3/Capacity Max
ak716
'Merica
462.0125 is now reporting TIIInonStd(MOT)...so CapMax.... Site L6-17 CC 7 RAS with Neighbors 1,2,3,4,10,11 and 26.
Looks to me like the CapMax switchover will be a direct swap, with site numbers included from the Con+ system.
I didn't notice any true activity other than the CC, but I also didn't see it last week, so it's new.
k2hz
Rochester, NY
Is there any indication of TIII activity on Site 2? I checked all frequencies I am aware of for the site and either inactive or Con+.
ak716
'Merica
Not that I'm finding. I just did the same. Con+ 171 is using 461.2500 for its CC as I type this on Site 17.
I'll leave it parked on there for a while and see if there is any activity, but seeing how it's probably in the initial buildout/transition stages, I don't expect anything beyond a tech or two maybe registering to it.
ak716
'Merica
462.0125 is Ch 1925/1926, also noted activity on Ch 1859, but I don't have that frequency yet. Looks like the same TGs and RIDs will be used, going off the 2 users and 1 TG I logged.
k2hz
Rochester, NY
LSN 1859 should be 461.600. One again, if these frequencies are Cap Max they need to be taken out of the Uniden Con+ frequencies for the Site since the scanners apparently can't tell the difference if the Color Code is the same so it is 50/50 what Control Chanel it picks to track.
If this activity is consistent on Site 17 please submit to delete the Cap Max frequencies from the Con+ Site frequencies.
ak716
'Merica
So, either DSD is messing up, which I don't think it did, or the CapMax and Con+ are using the same frequencies simultaneously. 461.6000 just had TIII data traffic on it, showing L6-17 CC 7, and then stopped. Then switched to Con+ and had voice traffic from 171-17 from known TG's. Moments after that, more TIII L6-17 data. So, I think that might become a problem to do it that way for tracking in the DB properly.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Don't know how true it is, but I remember a post from a guy in the Indiana forums talking about an Indiana wide area CON+ system upgrading to CAPMAX. And he said that the CAP+, CON+ and CAPMAX systems could coexist, intercommunicate, and use some of the same frequencies. Said CAPMAX was that flexible. Basically to aid in transition from CON+ to CAPMAX.
Again, no idea if that is factual or not.
Mike
lkas
Cheektowaga NY
I am manually adding this to my sds100. Is it programmed as a motorola turbo trunk system?
k2hz
Rochester, NY
Mike
If it is a voice channel, it can probably coexist in the scanner but once it becomes a Control Channel, it has to be locked out in the scanner in the other mode. It probably can coexist in subscriber radios with no problem but scanners aren't that "smart" to know the difference between a Con+ and and Cap Max Control Channel so they will randomly sit on either one.
k2hz
Rochester, NY
So, for the SaiaNet systems, if a site frequency is confirmed to be a Cap Max control channel that frequency will be deleted from the Con+ site frequencies. Any frequency that is shared Con+/Cap Max will be listed on both systems in the RRDB.
k2hz
Rochester, NY
Site 2 now active 463.6625. From NL data, it appears Site 6, 452.3625 and Site 16, 464.6125, are pending but not yet on the air. Sites 4, 10 , 11 & 21 do not yet have their control channel LSNs programed. Sites will be added to RRDB when observed on the air.
I don't expect any activity except testing until all sites are up.
k2hz
Rochester, NY
Site 2 Control Channel now 454.6625. No activity on the other pending sites yet.
Site 1 is now up with a Neighbor List of other Buffalo sites: 3,4,8,10,17,23,26.
k2hz
Rochester, NY
System buildout is progressing with CON+ channels being converted and/or new channels added at various sites.
The System ID had been changed to L5 during initial testing and I have confirmation that ID will be permanent. This ID does not imply any present or future connection with any other system.
I am working on submissions and my own observations. Channels converted to TIII must be deleted from CON+ programming for the site. Be aware that Sentinel does NOT support downloads of this and other TIII systems. Uniden Scanners seem to work if the data is imported from other programs.
k2hz
Rochester, NY
I have information that Jamestown: 461.5625 and 461.9250 and Olcott: 461.9250 and 461.3875 have been converted to CapMax. I have deleted them from SaiaNet CON+ in the RRDB and they should be deleted from your scanner. They are not yet added to the RRDB for Saia CapMax until I get the necessary DSD+ details from someone in the area.
I will attempt to post CON+ frequency deletions on this thread to make it easy to keep your scanner current for the system. I am checking all CapMax site frequencies as they become known to see if they are new to the site or a re-use of a CON+ frequency.
k2hz
Rochester, NY
I am seeing problems with the LCN/LSN information for the recently added sites so I have temporarily removed the Saia CapMax system from RRDB public display while I sort it out. I am confirming the correct base frequency and channel spacing for the 450 sites vs the 420 site which appears to be correct.
k2hz
Rochester, NY
I cleaned up a mess I made from some LCN/LSN confusion and the RRDB listing is back up. The fact that there is no regular voice traffic on the system yet makes ID of all Site frequencies and the associated LCN/LSN a problem with mostly only CC Neighbor List data to start from.
It may still be some time before there is any regular traffic on the system.
k2hz
Rochester, NY
Syracuse CON+ Site 25 deleted 461.6625. It is now CapMax Control Channel. Other recently added CapMax sites are on new frequencies.
NS9710
Niagara Falls, NY
Is there any specific changes needing to be made to the Uniden BCD436HP programming for the new system, or will the scanner automatically pick up the T3 system?
